I'm stumpped on this one. This will be the sixth time i've dropped the trans. The problem is the flexplate keeps rubbing on the block. It has cut a groove into the block and rubbed the end of the crank sensor off. I have pulled the flexplate off and put it on a surface plate to check for run out. It has .025 " run out. According to ALLDATA it's allowed up to .060
runout. There are no visable cracks anywhere on the flexplate. When I istalled the t.c. I made sure it was on all the way! It seems to bottom out
on the statorhub. I am dropping the trans at the momment. I have noticed that I cannot push the t.c. bolts out of the flexplate while trans is bolted to engine. I do remember having to line up the t.c. bolts to slide the trans onto the engine. I called the trans shop to see if they sold me the correct t.c. and they agreed it was correct. The funny thing is, I actually test drove the car and it shifted fine. If it were not for the ticking sound from the flexplate hitting the block, the rebuild would have been a success! By the way, it's a 1999 escort zx2 2.0L dohc.
I'm now going to check the crank shaft for exccesive walking. I beleive it's allowed up to .012.
I don't think thats the problem though, it ran fine before the rebuild.
Has anyone ever delt with such a problem? Or have any idea's.
