ZX2 vs. Escort 2 door | Ford Escort Owners Association (FEOA)
Discussion in 'ZX2 1998-2004 2.0L DOHC' started by L5wolvesf, Apr 26, 2019.
  1. L5wolvesf
    L5wolvesf FEOA Member
    13
    Northern AZ
    I'm a new guy to the Escort world. My question is what is the difference between a ZX2 and an Escort 2 door?
    I'm considering what car to build to race and the car's suspension and engine/drive train are to be essentially factory stock. Today I went on a parts yard stroll to check out the ZX2 and came across a 2 door Escort and it really didn't seem to be all that different from the ZX2s I saw. I'm hoping either one ends up being the "best" choice. So far it seems like a good candidate and I really don't want to run a Cavalier..
  2. madmatt2024
    madmatt2024 FEOA Member
    9,851
    412
    383
    Upstate N.Y.
    A 2 door Escort isn't worth racing in stock form stock unless its a GT model with the 1.8L, the 1.9L has 88hp and is a turd by comparison. If you can't find a GT then a ZX2 would be the next best choice.
  3. L5wolvesf
    13
    Northern AZ
    The engines, and more specifically the cam covers, looked like the same engine, the 2.0. The 4 cars I looked at looked the same and were all 2000 to 2002s. Did those year Escorts come with smaller engines?
  4. pextor
    pextor Moderator Staff Member
    5,941
    804
    Lancaster, pa
    All 2 doors from 98-2003 are technically "ZX2" even if they don't say they are.
  5. madmatt2024
    9,851
    412
    383
    Upstate N.Y.
    Correct. When he said 2 door I assumed 91-96 year Escorts because anything newer with 2 doors all have ZX2 badging on the car.
  6. L5wolvesf
    13
    Northern AZ
    Thanks for the info guys. So are the ZX2s equipped / upgraded differently then the 2 door Escorts?
  7. pextor
    5,941
    804
    Lancaster, pa
    If you are talking 98-2003 they are all the same. When you say 2 door escort, some people think of older cars, but I don't think that is what you are referring to, right?
    4cylinder likes this.
  8. L5wolvesf
    13
    Northern AZ
    Correct I'm only talking about 98-2003, but even more specifically only the years that do not have variable valve timing. VVT is verboten by IMCA.
    So whether the car is an Escort or a ZX2, of those years, they are equipped exactly the same meaning the ZX2 is not a "souped up" version . . . correct?
  9. Defunct SR Owner
    Defunct SR Owner FEOA Member
    27
    10
    13
    ZX2's are variable timing-the exhaust cam for fuel economy.
  10. L5wolvesf
    13
    Northern AZ
    If that is the case then my only Escort option would be a 90 to 96 GT with the 1.8 (not 1.9) engine. Does that sound about right?
  11. pextor
    5,941
    804
    Lancaster, pa
    Actually the Zetec in the ZX2 is VCT - Variable Cam Timing. Don't know if that makes a difference.
  12. L5wolvesf
    13
    Northern AZ
    I looked it up and the first thing I found was:
    https://en.wikipedia.org/wiki/Variable_Cam_Timing
    Bottom line seems to be they are the same.
  13. Tnashua
    Tnashua Gearhead / hot rodder with a soft spot for Scorts
    1,045
    235
    213
    Oskaloosa, IA
    I don't remember our 98 ZX2 being VCT, but maybe it was & I just missed it / forgot that it was... IMCA is being too picky! Are you sure they aren't forbidding the Honda VTEC engines?
  14. L5wolvesf
    13
    Northern AZ
    The Wiki link above specifically lists the ZX2s.
    IMCA may be too picky, but with many FWD cars having VVT set ups it is going to limit the number of available cars, and less cars isn't much of a race. Here is their rules in pdf.
    https://www.imca.com//wp-content/uploads/2018/12/2019-sport-compact.pdf
