Just like it says...Can a loose shifter stick be somehow tightened? Thanx
O.K. Thanks...How do I access them to replace them? Any special tool(s) required?white-lightning said:You probably just need new bushings for the shift linkage. Order the ones Cork Sport sells for the Escort GT. I got them and they took out 80% of the play in the shifter.
mechtech...Yes, I see that Energy Suspension sells a shifter stabilizer bushing set. Too bad they don't also offer the regular shifter bushings as well. I would buy them! Thanksmechtech said:You can also get a stiffer urethane bushing for the shift stabilizer rod [also underneath].
Grease the shift bushings - don't put them in dry.
Is that a lot of work?madmatt2024 said:If you want the stabilizer bar out of the car then the whole shifter assembly has to come out.
