put both seats all the way forward, remove the two screws on the sides in the back to remove the rear section of the console.
pull up on the rear section of the center console and it will unclip from the front section.
pull out on the little center section of the clips holding the front section of the center console in, and the clips will come out. there should also be two screws down in where the parking brake handle goes that hold the center console in.
the light bulb comes in from the bottom, should be a #914 I think? it's been a while since I replaced mine.
