ZX2 B&M shifter issues | Ford Escort Owners Association (FEOA)
Discussion in 'Interior Modifications' started by Toonces302, Jun 22, 2008.
  1. Toonces302
    Toonces302 FEOA Member
    31
    156
    I find this shifter to be stiff and notchy for the 1-2 gearshift. :mad: Also, sitting idle, stopped, sometimes you really have to muscle it to get it to go into 1st gear. :mad: When the engine is shut off, however, it should be noted that it goes into first quite easily. It's an annoyance really. Would synthetic transmission fluid help? http://www.amsoil.com/storefront/atf.aspx
    That's what I plan on using.
    Thanks in advance for your help.
  2. Dave94LX
    Dave94LX FEOA Donator
    5,787
    238
    Under the Stairs
    you must have torqued it down too hard underneith.... loosen it, and then torque it down til it is snug. Don't crank it TOO hard
  3. celery952
    celery952 FEOA Member
    1,985
    286
    Villa Ridge, MO
    yes, shifter to shift rod bolt is too tight
  4. Super_Wagon
    Super_Wagon FEOA Member
    128
    166
    Oregon
    When I put my corksport shifter in my 94' GT the shifting was pretty tight going into and out of gears. I carefully shaved a bit off the ends of each bushing until it fit in the shifter rod perfect without having to force it. But this would only help if you have the bronze-oil bushings as well as the short throw shifter.
