1 - 3 of 3 Posts
I just bought a new clutch for my ZX2 MTX swap. I’m going to the pull-a-part this week to get the transmission. If the yard doesn’t have a ZX2 trans, I’ll probably get one from a 3rd gen sedan. I know the trans will bolt up, but will the ZX2 clutch work with the sedan trans?
does anyone have any more info on this? I just read on jeff's cardomain that the zetec flywheel has larger diameter holes in it but is the same pattern.... so if I overcome this issue with sleeves to reduce the size back down and use a zetec clutch I am good to go? anyone know any more?
i figure the spline count is the same on the 2, but is the flywheel the same diameter on the spi and zetec?
1 - 3 of 3 Posts
