Engine - ZTEC Head on SOHC Block | Ford Escort Owners Association (FEOA)
Engine ZTEC Head on SOHC Block
Discussion in 'Engine Swaps' started by borgward, Nov 26, 2019.
  1. borgward
    borgward FEOA Member
    111
    168
    Is it possible to put ZTEC Head on 3rd gen short block? Do the 3rd gen SOHC and ZTEC share the same block? What's the difference? Different bore and stroke? Different crank?
    I notice that the ZTEC's have higher RPMS at same speed in high gear. I have 99 Tracer. It would be simpler to swap head than engines. Is DOHC head belt or chain drive. I can imagine some mounting points for tensioner, etc may be different.
  2. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,171
    665
    363
    Blocks are similar but not the same. This swap has been done but is very impractical. It is simply much easier to just swap the entire Zetec engine. Even better to grab the Zetec's manual trans too. The Zetec+Trans swap is 99% bolt-on swap.
    I give you the ZVH..
    Enjoy: http://www.quantums.info/zvh.htm
    The Zetec has longer rods, bore stroke are the same, I think the crank is the same.
    Engine specs: https://escortfocus.com/html/engine_specifications.html
    For the other question: the higher RPM is simply different gearing in the transmission. Transmission gearing dictates engine RPM vs. Speed, not the other way around. The Zetec's G5m manual has shorter gears and a 4.10 final vs the tall gears and 3.85 (or something) final in the CVH's G5M. It is a common practice to swap the 5th gear from a CVH trans and put the 5th gear into the Zetec's trans; as this will reduce 5th gear engine RPM a few hundred revs.
    EDIT: My bad CVH head on a Zetec block has been done. Zetec head on CVH block has not been done.
  3. borgward
    111
    168
    OK, Looks like head swap not practical. Whats involved with bolting Zetec engine to the 5 speed manual. I really want to reduce the RPM's in the top gear. I am not going to the drag strip.
  4. ShakeZilla19
    3,171
    665
    363
    Never done it but it is suppose to bolt up without modding think you need the Zetec starter.
  5. marclar
    8,968
    549
    seabeck WA
    IIRC, the pent roof style valve train on the ztec head interfear with the cvh dome top pistons. it COULD be possible, if you replaced with flat, or custom recessed pistons.. but that defeats the purpos.
  6. borgward
    111
    168
    I pretty much convinced the head swap is not practical.
  7. marclar
    8,968
    549
    seabeck WA
    did you post about this on the FB group the other day??
  8. 04Svt
    04Svt FEOA Member
    706
    220
    103
    The pistons on the sohc and Dohc are different. If your not willing to do the work I would just get a good used motor.
