1 - 14 of 14 Posts
looks like it may be a good upgrade from fords "PLASTIC EVERYTHING" cooling system components
I agree. It comes with a stant tstat and sensor. Someone said the price was high for what it is but if you subtract the tstat and sensor cost it comes to around $100 for the housing unit alone.
I'm thinking either polish it to a brushed machined finish or p- coat it some funky color to make it standout!
John
That looks like it is a Massive Speed Systems component. They also make underdrive pulleys and a bunch of other stuff for the Zetec. Their pulley seem quite well made.
I'm always happy when someone makes a decent part for our cars. Of course good stuff costs a bit of money, but no one has to buy it - it's just an option for those who do want a good part.
From a preliminary check it seems that Massive indeed sells it and is the cheapest from what I can see but I need to dig deeper.
John
Discussion Starter · #9 ·
Not for a ZX2.... Only has 1 fitting for the sensors ...
I swapped out the original tstat housing and replaced it with one out of a '98. It has one sensor on top like the one in the link.
Not sure what tstat you have. Do you have a pic of your dual sensor tstat housing?
John
Just saw the plug in the lower part of the housing.. There are 2 sensors on a ZX2 though, 1 is for the ecm, the other is for the gauge.
Wood Gas Machine Auto part Nut
Gas Nut Auto part Cylinder Machine
thats a good point. the outlets are different as well. it does say contour in the description, possible for a different application
After looking at that and a quick look on line, that is defiantly not for a ZX2..... It looks like one for a Contour or Escape.
There are some aluminum with 2 sensor ports, but the sensors are a different mounting style. That was the first mod we did with our current 2003. I’ll try to send a picture later today.
keep in mind the 2003’s use different coolant than all previous years which cannot be mixed.
So I remember how I worked this.
Called massive speed who makes these. They have two units (a 1 sensor port and a 2 sensor ports).
Tell them you need a two sensor port. Then you need to order sensors and an outlet. Their outlet is aluminum, but it is straight. You need to buy a plastic outlet (low cost at a autozone, advanced auto, etc.) for a previous year escort zx2. It may sound like a waste, but it is absolutely not. The corrosion & associated leaks come from the housing to the head, not from the outlet to the housing.
1 - 14 of 14 Posts
