Your random post whore thread. | Page 229 | Ford Escort Owners Association (FEOA)
Discussion in 'Off Topic' started by James92Scort, Dec 10, 2006.
  1. 88ESCORTV6
    1,198
    196
    313
    Hawkesbury Ontario
    one of the best ways to get them off the car after they have rusted and swollen up.
    denisond3 likes this.
  2. denisond3
    9,912
    2,677
    Yes. Was probably necessary - after the hex surfaces formed by the sheet metal 'skin' had been distorted enough that the original size lug wrench would no longer fit properly; so the mechanic had to use a smaller wrench size to undo the lug bolt. I used to run into this problem with my mopar vehicles, once they had about 200k miles on them.
  3. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,064
    909
    363
    Vancouver Island, Canada
    "I used to run into this problem with my mopar vehicles, once they had about 200k miles on them."
    ...and of course everyone knows that on Chryslers and AMCs the wheel studs on the left side of the vehicle are left hand thread, right?
  4. denisond3
    9,912
    2,677
    I dont know if or when mopar stopped doing that. I know they were doing it on their cars/trucks all through the 1950's and to at least the early 70's.
    I had a Winnebago, based on a 72 Dodge M400 chassis. It had the five bolt Budd wheels, with a very dim L stamped on the end of the studs on the driver's side of the vehicle, and an L stamped on the edge of those lug nuts too. The lug nuts for the curbside were unmarked. With the dual wheels on the back axle there was the lug nut for the inner wheel, which mounted over the studs on the drums. For the outer wheels there was a lug nut that had a large enough hole to thread on over the lug nuts for the inner wheels. Thus the vehicle had a total of six different lug nuts for the entire vehicle; the three different right hand threaded, for the 'curb' side of the vehicle, and the three left hand threaded for the driver's side of the vehicle.
    It was easy enough to have both of the front hubs (integral with the drums and studs) off the vehicle for doing brake work, and to put the hubs/drums back on the incorrect side of the vehicle. Then the next time someone took the vehicle in for brake work, the unlucky technician might mess up not only the lug nuts on the driver's side - which should have been left hand threaded (and werent), but also the lug nuts on the curbside, which should have been right hand threaded (and werent). It was also possible to swap the rear drums/studs, but I never ran into that.
  5. Joey_Twowagons
    2,064
    909
    363
    Wow, what an opportunity for confusion!
  6. austin86
    austin86 FEOA Member
    486
    85
    43
    Ohio
    [​IMG]
    I can't help but wonder how that happened.
  7. Joey_Twowagons
    2,064
    909
    363
    I think the stove was stuck into the already damaged truck just as a prank.
    austin86 likes this.
  8. 88ESCORTV6
    1,198
    196
    313
    Hawkesbury Ontario
    no it was put there to bring to the steel recycle yard to get cash for the metals. I see this every days around here.
    austin86 and denisond3 like this.
  9. copcarguy
    copcarguy FEOA Member
    1,976
    837
    263
    Northeast PA
  10. zzyzzx
    14,681
    1,077
    Supposedly 86,000 miles with no oil change:
    [​IMG]
  11. denisond3
    9,912
    2,677
    And lots of short trips in that 80k miles I bet. Is that a BMW 300 series head?
  12. 88ESCORTV6
    1,198
    196
    313
    Hawkesbury Ontario
    oups
  13. zzyzzx
    14,681
    1,077
    This is a neglected Toyota:
    [​IMG]
  14. zzyzzx
    14,681
    1,077
  15. austin86
    486
    85
    43
    Ohio
    At least its not a kid that has anger problems...
  16. copcarguy
    1,976
    837
    263
    Northeast PA
  17. zzyzzx
    14,681
    1,077
  18. Joey_Twowagons
    2,064
    909
    363
    Hey - they still worked!
    If you are going to replace the pads and rotors, might as well use 'em up!
  19. copcarguy
    1,976
    837
    263
    Northeast PA
  20. Joey_Twowagons
    2,064
    909
    363
    I'll take choice number one.
    That's pretty much how I do car repairs (and why I try not to do them for other people any more).
    copcarguy and austin86 like this.
