Yay new Engine time! =D | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by rufus196, Jun 14, 2015.
  1. rufus196
    rufus196 FEOA Donator
    149
    168
    Prince George, BC
    So i want your guys opinion on the BP is it easier to remove the transaxle then the motor or all at once in the EGT?
  2. Wilberforce
    Wilberforce FEOA Member
    201
    40
    178
    Northern Utah
    I would like to know also! But I'm going to pull them together because I need them both out.
  3. rufus196
    149
    168
    Prince George, BC
    Well if i had a hoist you could probably drop the whole sub frame but ive only got an engine crane so ya...
  4. Wilberforce
    201
    40
    178
    Northern Utah
    I was going to pull out the engine and trans before the sub frame but I'm pretty sure you don't need to remove the engine or trans to drop the sub frame. The two bay mounts and maybe a jack will hold it all.
  5. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    Taking the engine and trans out at the same time is the easiest. Removing the subframe is not a feasable idea.
