So, the problem at hand.
So I drove to the mall with no problems in the car at all, and when I leave, my cylinder stops working. I had gotten work done on it before, New fuel filter, 02 Sensor. My light does flash as I drive around, and it says I have a P1131 "System too lean" Code as well as the P0301 "Cylinder 1 misfire".
I replaced the Spark Plugs and the wires, and same problems. I've ran some down home testing with my friend, and decided to switch spark plug around between 1 and 3 and same problem. I did notice that spark plug 1 still had the smell of fuel on it and look practically new.
We did an "arc" test. We tested the electricity coming out of wire 1 and tested it on cylinder 1 and 3 and got no arc. However when we used wire 3 on 1 and 3, the cylinder worked
So I'm positive fuel injectors aren't failing as I though.
I would like to note that these are new wires, and I can only think it is the coil pack. My friend thinks it is the distributor, so if anyone can help us out, I would appreciate it. Thanks.
