1 - 3 of 3 Posts
Discussion Starter · #1 · (Edited)
$2,900 OBO
This is my running and drive-able project car. Selling because I don't have the time for her anymore. send me a text at 720-334-5620 if you're interested
WILL PASS EMISSIONS CAN BE USED AS A DAILY
Debadged
New timing area (belt, water pump, idlers,)
New valve cover gasket
Fresh oil change
Shaved off the radio antennae and door moldings.
Steel braided brake lines
New pads, rotors, drums, and shoes as well as a brake fluid flush
New Moog lower control arms and ball joints (both sides)
New Moog inner and outer tierods (both sides)
NRG Suspension polyurethane bushings
NRG polyurethane motor mount inserts
Ceika 1M racing coilovers 8Kg/mm spring rate in the front and 6Kg/mm for the rear
1 Camber bolt in each corner for extra suspension angle customization
Borla Pro 2.5 inch cat back exhaust
No name short shift kit (took shift throws from 6.5 inches down to 3) with a JDM style handle shift knob
DEI Heat wrap on exhaust
Interior almost fully gutted heat works AC does not. She's got a leak at power steering pump.
Wheel Automotive parking light Tire Car Vehicle
Font Office supplies Electric blue Art Auto part
Motor vehicle Plumbing valve Automotive tire Gas Auto part
Tire Wheel Tread Automotive tire Hubcap
Tire Wheel Car Automotive tire Motor vehicle
1 - 3 of 3 Posts
