WTF my Haunted Amp..... | Ford Escort Owners Association (FEOA)
Discussion in 'ICE (In Car Entertainment)' started by scrythe, Dec 14, 2006.
  1. scrythe
    scrythe Guest
    1,868
    this is weird, ok so i have my Hifonics brutus 1606d and I had it hooked up but my wiring to my subs was all wack-i-fied so i rewired them to 1ohm and hooked it up, i had a crappy ground connection and lost it (i had a 8awg wire hooked to a 16awg wire twisted with electrical tape, i know not safe and now the tape and 16awg is all melted, i had it hooked like that when i had my old amp and wasnt pumping much power
    NOW FOR THE HAUNTED PART i got frustraited trying to find a ground for the new 8awg wire and just cut it so the amp is not grounded now. I turned my car one and looked in my backseat (backseat folded down) at my amp to give it a dirty look and when i turned my car on the amp turned on and lit up for about 5 seconds and turned off, WTF how could it turn on if it was no where close to being grounded. how is this possible?
  2. jlongoria9
    jlongoria9 Guest
    4,242
    uhhh..... theres capacitors inside ur amp :roll:
  3. 4doorscort
    4doorscort New Member
    8,129
    5
    Brampton ON
    what kinda subs are they? dual 4ohm? and how many
  4. jamesm
    jamesm Guest
    1,085
    my old amp used to work without being grounded occasioanlly.. it was kind of wierd come to thinkof it cause its not supposed to.
  5. 96EscortLX
    96EscortLX New Member
    10,892
    Moved to the proper section :)
  6. 4doorscort
    8,129
    5
    Brampton ON
    are you saying it turned on for a split second, then turned off? and won't turn on again??
    some times with my home stereo after i unplug it while its on or something, it will still say its on for like 3-4 seconds
  7. Sekter
    Sekter Guest
    155
    actually, this happened to me in my old car, I used to have a 92' Crown Victoria, and i had my amp in the trunk along with 2 12's. Once when I was drivin it just cut out ( later i found out the ground came undone somehow) but it did the same thing, when I gave it power...it would light up for asecond but then die out and i didnt know what it was untill i just went over alll of the wiring, replaced the ground to a better position and it was fine.
  8. mtlhead
    mtlhead Guest
    311
    im no electronic genius by any means...but could it recognize the power, turn on, and then try to ground it, and then seeing that it cant, shut off?
    random thought
  9. jlongoria9
    jlongoria9 Guest
    4,242
    no, it stays on for a couple of seconds because they have capacitors inside that will hold a charge for a couple of seconds
  10. mtlhead
    mtlhead Guest
    311
    yes, but u still have an incomplete circuit, so neither of our answers really make sense
  11. jlongoria9
    jlongoria9 Guest
    4,242
    huh? a capacitor will act like a small battery only that it will not be able to hold the charge for a long time, so when u unplug it, theres still electricity on the capacitor therefore it stays on until the capacitor discharges. if u dont belive me unplug ur TV set and and open it and at the very top theres a little sucktion cup thingy...... grab it with ur hand and tell me how it feels :lol: dont ask me how i know :oops:
  12. scrythe
    scrythe Guest
    1,868
    jlo thinks hes smart
    btw. i got it fixed, found a ground but turned out i needed a new fuse aswell
  13. GTMechanic
    GTMechanic FEOA Member
    53
    158
    your capacitors in the amp could actually power it even if it was totally out of the circuit if you disconnected it the right way. an most amps can also turn on with absolutely no ground wire if you have it mounted to your vehicle chassis. most amps are grounded to their own case. in this condition it would come on but wouldnt play, or would barely play depending on how well you actually had the case grounded
  14. 4doorscort
    8,129
    5
    Brampton ON
    i grounded at my seat back seat bolt the part thats in the trunk where the seat folds down, make sure to sand down the paint, so its raw metal exposted to the ground wire when you attach it
  15. scrythe
    scrythe Guest
    1,868
    thats what i did but i said screw sanding, luckily i didnt need too, works great
  16. 4doorscort
    8,129
    5
    Brampton ON
    meh, its all good, lol
    long as it works i guess...
