1 - 13 of 13 Posts
8O holy skuce where you been hiding?
i have a pair of clear's
hmm never knew there were different styles.
chrisanthony14 said:
Skuce said:
91-92 or 93-96 style?
Hi
I think its 91-92. They only have a little bit of the yellow reflecter at the end and the rest is all clear. It would fit my 96 escorty correct
No you misunderstood.
Since you have a '96, you need corners from a 93+ Tracer. 91-92 won't work (without a litle fabbing). The 91 bulbs are different than a 96.
Hi
Hi
THanks you are right..I'm looking for some 93 corner lights..
If anyone has them can you let me know
thanks,
chris
91-92 uses an 1157 and 93-96 uses a 3157. It's just a different bulb connector and sadly they do not interchange. But thankfully the wire colors are the same so I just changed mine to the newer style.
you can use any tracer corners u just have to cut the harness and match up each colour wire theres 3 wires the colour are the same. i have some. clear and tracer ones.. again it doesnt matter u just have to slipce the wires its a 5 min job. wire strippers and some electrical tape and bobs ur uncle.
1 - 13 of 13 Posts
