Would you just replace the starter or just the solenoid. | Ford Escort Owners Association (FEOA)
Discussion in 'General Discussion' started by austin86, Oct 4, 2019.
  1. austin86
    806
    271
    78
    Ohio
    So I'm working on this old jag I'm going to be selling, it ran fine up until the day the starter had problems.
    The starter spins but does not engage with the flywheel.
    Seeing that a new starter with solenoid is about 200$ and a solenoid is 20$ would you take the chance of just replacing the solenoid or would you get a new starter all together?
    Most of the time if a starter goes bad in my cars I just push start it, so I'm not the best one to ask for starter repairs.
  2. zzyzzx
    15,039
    1,181
    Remove the solenoid and bench test it. If the solenoid bad, just replace the solenoid.
  3. ZX2.0
    ZX2.0 FEOA Member
    132
    57
    88
    It may not be be the solenoid. I've seen several that had broken the plastic arm that throws the gear out. Primarily in Ford PMGR starters, but some imports as well. [​IMG]
    Sent from my SM-N950U using Tapatalk
  4. austin86
    806
    271
    78
    Ohio
    I'm gusseting I just run 12v to it?
  5. austin86
    806
    271
    78
    Ohio
    I'll defiantly take a look at that too.
  6. marclar
    8,928
    527
    seabeck WA
    usually its the rod that actuates the drive gear and not the sol. i would replace the whole thing as a unit personally..
    i am going to move this to the
    "general discussion" section.
    austin86 likes this.
