got the front right mount on, couldnt do the other two,was given the wrong one, so it will be tomorrow before i can do that. well the car was still starting and dying, i looked, checked all the the conectors,lines,etc to see if any were broken, nope. Well i recalled that i made a new gasket for the map sensor, because when i took it out to inspect it, the gasket broke. so i unconnect it, and start it up, runs fine! hook it up dies!
so i left it unhooked, so the car runs fine, so what is the point of this goofy pos on here, if it has no effect on the car's running condtion?
also the battery light is on, yet the alternator works fine, and the battery is good, i have a 500 watt amp hooked up to the car, would this cause the computer to think the alternator is no good, because it thinks there is a drain?
