wont start, no lights, only check engine | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.9L SOHC' started by brackaj33, Dec 1, 2012.
  1. brackaj33
    brackaj33 FEOA Member
    17
    5
    153
    Tualatin, Oregon
    Ok, turn key and only the check engine light comes on. No other lights. not even the seat belt retracktors move. It was driving fine, the after a quick stop at the liquor store it wouldnt do much of anything. I have checked the battery, the starter, any fuses, relays or fuseable links I can find, shut off switch, ignition switch, ignition cylinder and looked over damn near everything. What could I be missing?
    The BBE is a 1992 1.9 Pony
    (Bitchin' Blue Excort)
    Thank god it got me to the liquor store before it died.
  2. LeraiPalmer
    LeraiPalmer New Member
    156
    Milwaukee/Tomah, wi
    Hmm.. still sounds like an ignition issue. Check your battery cables and clean the battery terminals. That stuff can get corroded and u can still get a little bit of power but not enough to get the car going. Can you hear a click coming from the engine compartment when you turn the ignition?
  3. zzyzzx
    14,685
    1,079
    :agree:
