95 wagon, engine is a 1.9, first started out would have trouble starting and running intermittently, last wed would not start, it would crank, it would want to start, it tries to fire, but wont, I checked for fuel pressure, just trickle from valve, changed fuel pump, filter is ok, now there is pressure at valve, I also changed timing belt and water pump, all vacuum hoses ok, did shake test on connectors, no change, and after all the repairs it does the same exact thing as before the repairs, I also checked the plugs when it died and they were fuel black, not oil fouled, cleaned and regapped plugs. I also noticed an occasional minor backfire when cranking, also when it sits a while it will start but will run but real rough and stall, and wont start after that.
Checked spark-ok, checked injectors with noid-ok, checked-no codes.
Also when I try to hand turn the crank to align the timing marks it locks up and I cant turn it by hand anymore, but it will still crank using the starter.
I can do V8's in my sleep but I am a noob at these 4 cyls.
