Won’t start heater core replacement | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by Brendon, Dec 22, 2018.
  1. Brendon
    Brendon FEOA Member
    17
    I was not using brake cleaner. The head gasket and intake gasket are newer, it looks like felt pro blue gaskets. But I’ll give it a try.
  2. Brendon
    Brendon FEOA Member
    17
    Would a bad valve cause this problem.
  3. Intuit
    Intuit FEOA Member
    7,493
    902
    Southwest Ohio
    Could a bad Idle air control solenoid cause wildly high idle? Yes. I was futzing around with mine, cleaned and over-lubricated it. My idle then rapidly oscillated from 400RPM to 4 or 5k then back down. It startled me to the degree that I didn't dare restart it without replacing it. But I already knew that it was compromised due to its behavior prior to futzing with it.
  4. Brendon
    Brendon FEOA Member
    17
    I replaced the idle air control.
  5. Intuit
    Intuit FEOA Member
    7,493
    902
    Southwest Ohio
    You had said that earlier. My assumption was that it had zero impact. Was that the case?
  6. Brendon
    Brendon FEOA Member
    17
    Ya it dident do anything. I was pretty bummed. I planned on flipping this car due to it only having 72 thousand miles and I paied 400 bucks for it. Well the jokes on me.
  7. Intuit
    Intuit FEOA Member
    7,493
    902
    Southwest Ohio
    I still strongly suspect that the issue is related to unmetered air.
  8. Intuit
    Intuit FEOA Member
    7,493
    902
    Southwest Ohio
    If you bought with this problem and don't know what they did to it, then it could be anything. But if it worked fine before and the problem just cropped-up, then my strong suspicion is unmetered air.
  9. Brendon
    Brendon FEOA Member
    17
    Iv replaced all kinds of hoses and anything that is cracked. This is a disaster and my wife is pissed at me.
  10. Brendon
    Brendon FEOA Member
    17
    The person I bought it from was a airforce pilot that couldent change his own oil. Before that I’m not sure of the history.
  11. Intuit
    Intuit FEOA Member
    7,493
    902
    Southwest Ohio
    Any evidence that its been in the hands of a "modder"? They can be the absolute worse type of owners to follow up. Like Trump assumes he knows more than the generals, they assume they know better than the engineers that built the thing... and they screw stuff up.
    You haven't yet taken the proper diagnostic steps of testing first. Just replacing parts, and getting nowhere, yeah, that can quickly turn to a frustrating affair. Worse move I ever made was needlessly replacing a clutch disc over a dead engine miss; just needed spark plug wires.
    Test with a vacuum gauge per interpretation instructions mentioned prior.
    If a vacuum leak is confirmed, spray flammable liquids around stuff, especially where the intake meets with the head.
    rbailin likes this.
  12. Brendon
    Brendon FEOA Member
    17
