Wiring | Ford Escort Owners Association (FEOA)
Wiring
Discussion in 'Circle Tracks' started by CrewCheif75, Jul 5, 2010.
  1. CrewCheif75
    CrewCheif75 New Member
    55
    Hey everyone i need to know what wires u need to keep to run the car i wanna get rid of all the wires that i do not need if someone knows every wire and could tell me step by step for each wire or somthing so i can get rid of all the mess and everything i do not need for it to be a race car thanks
  2. dirttrackracer25
    dirttrackracer25 New Member
    324
    its a process of elemenation get a manuel and go from there probally take about 3 hrs i think it took off about 15 to 20 pounds of wiring mine is stripped completely except for motor, fuel, and gage cluster
  3. CrewCheif75
    55
    i have a manual but im not very good at readin the wiring diamgrams thats why im askin for help
  4. dirttrackracer25
    324
    i didnt use a mnauel either just start from the rear andf work ur way to the front just dont touch the wires that go from fuel pump or from the computer and ignition
  5. Redlined_Man
    Redlined_Man New Member
    126
    Montfort WI
    I took ALL my un needed wiring out of my car. It took me and a buddy about a day to do it. Like dirttrackracer25 said, its all done by process of elimination. cut a wire and start the car, cut a wire start the car. Do that and as long as the car starts your good. just remember there are 2 wires fromt he rear that need to be twisted together for your fuel cut off switch. I also did the wires under the dash and under the hood that way too. I dropped about 30 lbs out of my car by doing it.
  6. denisond3
    10,045
    2,776
    I think if you read the Electrical and Vacuum Troubleshooting Manual until you understood it; - then removing all of the un-needed wires would only take about a month of 12 hour days!
