wiring confusion | Ford Escort Owners Association (FEOA)
wiring confusion
Discussion in 'ICE (In Car Entertainment)' started by Firstsgtsteiner, Jul 12, 2006.
  1. Firstsgtsteiner
    Firstsgtsteiner Guest
    29
    ok i am confused on 2 wires for my head unit...
    First off i have to wires (on harness) one (yelow) labled 12 volt memory and another (red) labled 12 volt power....now on my head unit i have 2 wires left one (yellow) labled battary and another (red) labled accessory....so what do i connect what to....
  2. Firstsgtsteiner
    29
    btw the instructions say to connect teh wire that supplys power when the key is turned to acc or on to the power wire (red on head unit)
    and connect the wire that suppys continuous power for the clock and radio presets to the wire labled battary (yellow on head unit)
  3. ryanrules
    ryanrules FEOA Member
    5,209
    338
    Pennsylvania
    do you have a multimeter?
    with the car off, put your negative lead to ground and the positive lead to the redwire. if you have no voltage, turn the key on. if you have voltage when the key is on, thats your switched power source.
    do the same to the other wire. if the previous wire was the switched, then this wire should be the constant. double check it just incase.
    anywho.. did you spend the 7 dollars or whatever it is for a wiring adapter that just plugs right in?
  4. Firstsgtsteiner
    29
    ehh no multimeter ......and yes i have the harness (it came free with the 3ed gen dash adapter)
  5. ryanrules
    5,209
    338
    Pennsylvania
    hmm. i dont remember having to do anything special with my 3rdgen adapter.
    but after reading it again, it looks like yellow to yellow and red to red.
  6. Firstsgtsteiner
    29
    well this is pissin me off...its working...to an extent......its getting power (i can hit "display" and bring up the clock, eject/load disk ) but its not turning on to play music......i might have a bad unit???
  7. EGTERIC
    EGTERIC New Member
    2,417
    Glendale Hts. IL
    I had this same type of issue with my sentra I used 2 have and It ended up that out of all the options for the 4 wires connecting them all worked best. My cd player worked and so did my dash lights which was a problem depending how it was hooked up. so try connecting all 4 and seeing what happens it should be fine if its a newer headunit it will have a surge protecter incase it shorts or sumthing....but i take no fault if it fucks it up thats just how my kenwood was with my 93 sentra xe
  8. CaliScort
    CaliScort Guest
    2,979
    To make it so your dash lights don't turn on while ur head unit is on is to not plug in the "orange" cable. That's what I did. Wire everything else up according to color.
  9. Firstsgtsteiner
    29
    everything is right i had a blown fuse and couldnt figure out which one it was....turns out the "constant Current" for the radio is wired through the power mirror fuse......and it was blowing the 2.5 fuse so a upgrade to a 7.5 fixed it!
  10. Whitie_Bear
    Whitie_Bear Guest
    2,757
    yellow to yellow red to red
    or if your like me and you dont want to have to turn your car to acc or on to turn on the radio (using the key) then wire red to the yellow and yellow to the yellow, but then you must turn your deck off every time you shut down the car. No biggie for me, but now i have it hooked up the wussy way that needs a key, just because i have a fantom face deck that hides
