1 - 11 of 11 Posts
Hi guys, my 93 LX wipers don't move at all.
I changed wiper motor yesterday, didn't work.
I tested the two connectors to the wiper motor. No matter the switch on or off, the readings don't change. On the black one, I got 14.7V, 12.8V and ground. On the white one, I got almost nothing. like 0.1 and 0.4v.
What could be wrong?
Thanks.
The relay should click if it is good.The switch you would need to pull it and just test it like you did the wiper motor.I would first replace your relay before pulling the switch.99% of the time it is just a faulty relay.
Discussion Starter · #8 ·
Okay.......... I found the relays. But which one is wiper relay?.........
I pulled out a white one, Imasen H270, which has 4 pins and a yellow one, Imasen BW0G, which has 5 pins.
I didn't get any info out of Imasen website.
I have both Chilton's and Haynes, but they don't have much info on relays.
Please Help!!!!
Discussion Starter · #10 ·
I found them above the fuse box on the driver side. There are 5 of them.
According to Haynes, it should be one of the two I pulled out. Chilton's manual doesn't say much about relay.
Where is your multifunction switch? 96 and 93 are basically identical, right?
Thanks.
1 - 11 of 11 Posts
