1 - 2 of 2 Posts
Hi everyone
I just got another 95 EGT, problem with wiper. When using the washer, washer works but the wiper doesn't come on, and the intermittant option doesn't come on at all. The regular setting works fine.
Is it the column switch, or the control module/relay? If so, where is the module?
Thanks
Sounds like that would be the problem :wink:
http://www.feoa.net/modules.php?name=Forums&file=viewtopic&t=4821
It's for a 3rd gen, but I am pretty sure they fit 2nd gens as it looks identical. Just be sure to get the style with the intermittent option as they have both. Even if for some unconcieved reason it wouldn't fit, the module is probably 100% the same so you could swap them as just the module is removeable (probably have to remove the whole switch to get at it though).
Hope that helps :D
Matt 8)
EDIT: See http://erdtforum.teamzx2.com/viewtopic.php?t=8702
1 - 2 of 2 Posts
