How do you remove the window belt mouldings and window belt weatherstrips (the weatherstrip and moulding the runs along the top of the door panel that when the window is down you would be resting your arm on). Mine, for some reason, on the driver's door, does not touch the glass and is allowing water inside the door shell when it rains. I want to try and adjust or replace it but can't figure out how it comes off.
