1 - 3 of 3 Posts
Got these and he will mount and balance as well all for $60. He said the came off a Toyota and they are 5 1/2 x 13. The holes line up on the studs perfectly although I will need larger lug nuts. Curious about after tire is mounted and clearing the strut. What do you all think? Will they fit ok?
Those look like they are off a forth gen celica gt. It's a FWD car and I'm fairly certain that the lug pattern is 4x100. If you say you already tried putting them on sans rubber, they should be fine.
I havent had the rubber on the rims yet...I only took one of my wheels off and placed one of the rims on the care to see if the holes matched up ok.
1 - 3 of 3 Posts
