1 - 4 of 4 Posts
it shakes when stopped and does not shake when i am moving (also it shakes dramatically more when i turn on the AC)
I would definitely check your motor mounts. The A/C puts additional load on the engine causing it to idle lower, you would feel more vibration from that. But it def. sounds like a engine thing.
Well, when i got my wagon, it was running terribly.
First thing i did, cleaned the MAF Sensor, Then I Seafoamed the car, then I cleaned the IAC in the throttle body. She runs great now, Although my lifters need some work. Other than that, perfect.
1 - 4 of 4 Posts
