Which oil do you use? | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in 'General Discussion' started by pos_clunker, Sep 15, 2006.
  1. Mobil 1
    0 vote(s)
    0.0%
  2. Royal Purple
    0 vote(s)
    0.0%
  3. Corn Oil
    0 vote(s)
    0.0%
  4. Dinojuice
    0 vote(s)
    0.0%
  5. Other (Please Explain)
    0 vote(s)
    0.0%
  1. RoadWarrior
    RoadWarrior FEOA Member
    1,326
    29
    198
    Niagara Falls
    What I'd expect from re-refined used oil is that all the weaker molecules have broken down in previous useage and have been removed, and that it probably has more refinement and testing done to it than fresh stock. Ergo, you're left with oil that's less likely to sludge, burn or break down. Probably almost like a synthetic, but instead of it it going through a plant to be modified, it went through someone elses engine, first which "used up" all the sludge and gum tendencies out of it, then was processed back to pure oil again. Heh, I bet if the same stuff was processed over and over again (Returned used, re-reprocessed) and went round and round through dozens of engines, then you'd end up with an oil that could go 10s of thousands of miles between changes.....
  2. zx24me
    zx24me Guest
    3,559
    That's an interesting hypotosis Roady, but there's a fly. All the oil is probably dumped in one big tank to be re-refined (is that a real word?).
    But it's like home made bio-diesel: your using the old oil twice, thus less bought from the 9-11 kamikazes!
  3. jtugfestiva
    jtugfestiva Guest
    14
    For me i use walmart synthetic 10-30 in my festiva, mobile clean 5000 in my escort and Royal purple 5-20 on my Ford fusion
  4. mk96
    mk96 New Member
    1,020
    Moorhead MN
    I use mobil most of the time unless its not on sale...then it's fleet farm brand or whatevrs cheep...been usin 10w30 lately tryin to cut down on the oil burning in the gt...which really shouldn't be only having 40k on the motor.....
  5. 1lowscort
    1lowscort FEOA Member
    3,066
    288
    Missoula, MT
    3 qts castrol 10/30
    1 quart lucas
  6. zzyzzx
    15,237
    1,235
    Mobil 1 full synth 5W-30. With both the original engine and the Jasper engine.
  7. bluefoton
    bluefoton Guest
    223
    Olive oil, virgin. :D
  8. shiftedreality
    shiftedreality Guest
    12
    new oil isnt as clean as recycled oil too....
    especially with heavy machinery, they tell you that if you are using new oil that it must be run through a filter before it enters the resevoir....it doesnt meet specifications for particulate count for bearings
    you should run the oil through a filter regardless if its new or recycled, but recycled oil is filtered, plus it has all the additives restored.
    you change your oil not neccessarily because its "dirty", but because of the additives breaking down in it, and they must be replenished. the oil you buy to put in your motor(in taking about the petroleum based stuff, synthetics are in a different league) are 22-35% additives. 8O
  9. Abarthel
    Abarthel New Member
    1,849
    It depends were you live, here the super tech is the same; as say havoline.
    Its because here in north carolina its pumped into the refinary in one pipe, then after being refinedm its sent into one tube to a truck that takes it to a botteling plant.
    So here your just paying for the name.
  10. Kauai96LX
    Kauai96LX New Member
    1,053
    Kauai, Hawaii
    Am i the only person that runs royal purple? i got a bump in gas mileage from 32MPG to 35MPG. but at $7 a quart i might change later.
  11. redline5th
    redline5th Guest
    484
    Castrol GTX 10w 30
