does anyone know the part # of the MSD DIS ignition box that work with the 91-96 1.9L's? i need to get my hands on one considering that its the only way to advance/retard the timing on this damn car
Slot the holes the crank sensor mounts through and just adjust it that way. It would work just like retarding a distributor.tokstad said:Anyone know where to get them cheap? I see them going for 250-320 new on ebay, about 150-200 used, and about 330-380 retail. Plus you've got to buy a tach adapter box for the 97 PN#8912 (these run 40-70)
I really need to find a cheap way (right now 400 bones isn't an option) to retard my timing after about 2800 rpm or about 3psi boost....
You said you wanted cheap......cheap isnt always perfecttokstad said:Then I would be running with the timing retarded when unboosted. This would reduce low end power and efficiency.
Don't know if that works or not. I believe the DIS module takes its paramaters from both the crank trigger and the cam sensor.mikeflys1 said:Slot the holes the crank sensor mounts through and just adjust it that way. It would work just like retarding a distributor.
