1 - 3 of 3 Posts
Hi, I was wondering what cars, if any have compatible parts with my 91 GT. I am curious because if I were to go to a junk yard and pull parts as replacements/spares, I would think I could use parts from a lot of other cars. I assume the tracer works. Im also curious about what other gen2 escorts would work. Specifically, if I were to pull the front knuckle assembly (including the wheel bearing) from another car, what kind of cars could I look for? Would it have to be a 91 GT, or could a 91 LX do the job? How about a tracer, or say a 94 GT? Any thoughts? I just figured this may be cheaper and easier than replacing some parts such as the bearings.[/b]
Any car with a 1.8 BPD8 in it will work including:
91-96 Escort GTs
91-96(?) Escort LX-Es
91-94(?) Tracer LTS (discontinued I believe in 94)
90-94 Mazda Proteges
Early Mazda Miata LS 1.8s (although intake faces other way due to RWD setup)
Yr: ?? Kia Sephias, it also uses the 1.8 BPs.
Those all have the same engines.
As for suspension I believe you could fit some Escort GT rear discs on a late model Escort.
Escort Wagons have the thickest rear sway bar, they'll fit on the GT or any other Escort (I believe only in the 91-96 era).
91-96 Escort GTs
The 98 and earlier Kia Sephias used the Mazda BP engine, but nothing else on those cars are the same as the Escort.
1 - 3 of 3 Posts
