I got my amp and now I need to get to the battery from inside the car. Where is the best/easiest spot to get thru the fire wall. :?:
I have 4 gauge wire both positive and negative runing thru the gromet by the brake pedal.You have to be real careful when you drill.You dont want to hit any wires.FordBoy4ever said:or you could drill a hole... like stereo stores do alot of the times... then they throw a gromet on it and viola, hole in the firewall... that is what i did, when i had my dash out i wanted to re drill the hole up just under the diagnostic box thing because that would be much cleaner, i would not have a mile of line run under my hood but i couldnt find a large enough bit for my FAT 8 gauge wire![]()
