where is the ecm located on 94 gt manual | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by yeaman5, Apr 25, 2013.
  1. yeaman5
    yeaman5 FEOA Member
    78
    16
    Danville, Va
    I found a 94 gt escort manual in pretty good shape. but the guy said he is not getting any spark to the coil. he suspects it is the ecm, but I'm not sure where it is located. he has replaced the timing belt and wires and thinks that's what it is
  2. waffles
    waffles FEOA Member
    22
    33
    Racine WI, Long Island NY
    it is located under the dash, right in middle. pop off the panel on the passenger side of the center counsel in the front and you will be able to see it. what happens is the heater core leaks down on it and causes problems. you can unscrew the cover on it and visually inspect everything
