1 - 3 of 3 Posts
i just noticed that there's not a whole lot of clearence between the spring and the wheel assembly. Are 205 series tires (16x7 rims) going to rub? If so, what can i do to to modify it so it wont?
Chris
205s will fit fine.. except for the rear fender lip on 2nd gens. You may need to roll the rear fender lip out of the way. Keep an eye on the rear sidewalls for any indication of scuffing or cutting.
If you are rubbing against the strut, then your 16x7s dont have the correct offset. You can fix that with spacers.
alright, that's good to hear. I'm driving a 3rd gen (2k) so hopefully i won't have a problem. The offset is 40mm, American Racing.com says 16x7 w/ 40mm offset will fit, so hopefully their right. Thanks
Chris
1 - 3 of 3 Posts
