1 - 8 of 8 Posts
I have a 1998 Ford Escort Zx2 and was wondering what kind of symptoms I should be looking for if I have a bad wheel bearing(or both). Whenever I turn to left it makes a grinding noise, certain pumps will make the left front side of my car squeek. Could this be my CV joints too?
Thanks
Stilgar
Humming is usually associated with wheel bearings.Usually clunking to me sounds like a cv joint.I have a grinding noise coming from my front passenger side and I looked at it.It turns out to be a bad rotor on my case.I would say check your rotors for debris and pitting.I would check your tie rods for play.
I would change your tie rods and ball joints.Do you have aftermarket rims on the car?What I mean is wheels that arent the ones that came with the car.Because I remember correctly having a grinding noise when I was driving with my rims and it was my tie rods and a squeeking was my ball joints.
To diagnose a faulty CV joint, if you're moving forward, the left one is toast if you get a nasty clunk while turning sharply RIGHT and vice versa (usually from a stop). Doesn't sound like that's your problem.
Tie-rod and and ball joints can be checked readily with the front end jacked up. For tie-rods ends, check for looseness by grabbing the front and back of the tire and trying to move the tire in the direction that you steer (ie left/right). For ball joints, check for looseness with a pry bar between the steering knuckle and the ball joint housing (don't pry on the boot).
I'm inclined to say your tie rod end(s) is/are shot, but I wouldn't a-s-sociate (damn word filter) a toasted tie rod end with a grinding sound. Jack it up and take a good look around.
1 - 8 of 8 Posts
