1 - 14 of 14 Posts
Re: all i can
lowescort said:
all i can to make it fast as possabile
Get rod's/rod bolts, Piston's, headgasket/head bolts and you should be good to a little over 300hp.
Stock long block should be good to around 220hp safly with a perfect tune.
Re: all i can
By that do you mean that with stock internals you can safely run around 200 hp if you do it right? >.>
Re: all i can
sethxtreme said:
how hard is it to get a "perfect tune"????
Just need money for good engine managment: Custom chip/42# injectors and a big MAF would be the way to go. Then just dyno time and possibly tweek the chip.
Re: all i can
Correct, as long as you have the engine managment to support it, the stock long block should have no trouble with 220whp.
Beaverboy said:
Jeff, are you talking wheels or crank?
Crank for sure, possible wheel.
I'm at 188 wheel ft lb's, with a really rich tune, and junk yard part's. I feel I'm just getting started.
I have talked to a few people that have had there mostly stock 1st gen's at 300whp. Phil from TurboFord.org, turboegt from ERDT and 73runabout from TurboFord was also very high.
1 - 14 of 14 Posts
