What's the mileage on your generation 1? | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by FordMan59, Nov 17, 2008.
  1. FordMan59
    FordMan59 FEOA Member
    4,552
    442
    333
    Russellville, Kentucky
    I got this idea from a thread on the generation 3's. My '88 Pony has 483,743 miles and has never been rebuilt. Just pour in quart of oil about every 1000-1200 miles and keep driving it. After reading the mileage on some of the generation 3's I figure some of the generation 1's should be very high mileage.
  2. marshpoprock
    marshpoprock FEOA Member
    1,924
    41
    298
    Southwest,PA
    86 with 34 something thousand original
    87 with 63 something thousand original
    88 with 81 something thousand original
    89 with 58 something thousand original
    90 with 21563 original
  3. FordMan59
    4,552
    442
    333
    I knew you were an exception to the high mileage rule. In those 5 you should have over 2,000,000 miles left in them. The question is are you going to wear them out or are they going to wear you out?
  4. 1lowscort
    1lowscort FEOA Member
    3,066
    288
    Missoula, MT
    My EXP has 153k, and on its...I stopped counting how many engines and engine rebuilds I have put in that car. The original engine blew up at 134k
  5. marshpoprock
    1,924
    41
    298
    Southwest,PA
    I'm already wore out. I work on Chrylser products all day.
  6. Suff
    Suff Guest
    58
    90 with 66 something thousand original
  7. UnexplodedCow
    UnexplodedCow FEOA Member
    7,042
    177
    363
    Central Ohio
    '90 with 159k, and about 27k on the engine since the rebuild.
  8. 89SilverLX
    89SilverLX Guest
    38
    1989 with 52K original.
  9. cadaver
    cadaver Guest
    40
    88 with 85,000 original
  10. WJC
    WJC Guest
    524
    We complain about Fords...but when it comes to retarded, ass-backward engineering Chrysler wins hands down.
  11. UnexplodedCow
    7,042
    177
    363
    Central Ohio
    My vote would be for the 80's GM products. Smog control....yeah. Nothing controls the smog, and saps power, like air pumps, low compression, poorly jetted carbs, and early generation catalytic converters that like to fall apart inside and block the exhaust.
    After that I'd say AMC with severe electrical problems.
  12. FordMan59
    4,552
    442
    333
    Wow, Is this all the 1st generations there are on the site?
  13. zzyzzx
    15,242
    1,236
    My 1985GT had 160,000 miles on it before the engine blew. And yes I drove it pretty agressively.
  14. FordMan59
    4,552
    442
    333
    Are you rebuilding the engine or getting rid of the car?
  15. SVTADAM
    SVTADAM New Member
    518
    Connecticut
    Im almost cresting the 100k mark. Probably tomorrow...
    Woot!
  16. jfarcas
    jfarcas FEOA Member
    567
    166
    Athens, OH U.S.A.
    About 180k on my '89 LX 2 door 5spd. Still running strong! Gets 35MPG consistently (mainly stop/go driving). No weird mechanical noises, strong tranny and bearings and engine internals - even in this cold [email protected]# weather!
  17. 89Pony
    89Pony New Member
    260
    Indianapolis
    Well, some of us who have posted here awhile have stated our mileage a time or 2 in other posts. Mine has 140k (the one in my sig), and leaks or burns some oil but I can't figure out how much, lol. The oilpan is always coated w/oil, though I never see any drip off, so there must be some leakage. After the shop replaced my timing belt recently, I mentioned that the oilpan was coated w/oil and asked the manager (not the one who did the work) if he thought the seal at the crankshaft pulley was leaking and he claimed that they would have checked that when they replaced the timing belt, so he believes it's the gasket instead, instead of that seal.
    After the mechanic replaced my belt, he claimed the oil was low so he added a quart, lol. There is some light smoke from the exhaust but it doesn't smell like a lot of burned oil smell. I should do a compression test on the cylinders. I have difficulty trying to read my dipstick, as I mention in this thread: Hard to read engine oil dipstick level
    When I joined this forum about a year ago, i went back thru some old threads and read the Roll Call thread and kind of got to know the people here and their rides a little bit.
  18. al4171990
    al4171990 Guest
    38
    90 GT 78000 miles never rebuilt burns absolutely no oil very very well kept over the years
  19. zzyzzx
    15,242
    1,236
    I got rid of it in Oct 1995, when I bought my 1995LX to replace it. Hence the had part of my original post.
  20. Wingnut
    Wingnut Guest
    25
    '87 4-door hatchback- not quite sure either 36k or 136k? Either way she's still kickin!
