1 - 18 of 18 Posts
fuel cutout is the car cutting off fuel to the engine. when u start ur engine, it acts like a choke, it sends a lot of fuel to get the system going. When its sent enough(usually within like less than a second) it pops up to cut off the fuel to keep from flooding it.
the actuall use for fuel cutout is for when u wreck, the system is designed to cut off fuel to prevent ur tank from blowning up or spilling fuel causing a hazard.
Also, the engine runs through almost all the lights when u start ur engine sort of like a "test" for all operational equiment.
hope that helps.
Also, if you have the 1.8 GT engine if you open up your trunk and look to your left you´ll see a little piece of plastic that pops out. there´s a button or a switch in there that if you want to disable your car you can hit that, keep fuel from gettin to the engine manually. but yeah it´s designed to cut fuel from the engine in case you get in an accident so nothing sparks...I bet if we went to nukewaters old car and tried to turn it on it´ll say fuel cutout on the dash :cool:
[/TD][/TR][TR][TD]
02-04-2003 at 20:14, 92gt5spd wrote:
*feel like startin crap for no reason*
"alos, if ur james, u cant drive and u´d prolly end up using that fuel cutoff because u cant keep ur car on the road"
:p
[/TD][/TR][TR][TD]
[/TD][/TR][/TABLE]
What can I say? my car sucks lol :-]
[/TD][/TR][TR][TD]
[/TD][/TR][TR][TD]
[/TD][/TR][/TABLE]
I had the fuel cutout go off when I hit a partucularly nasty pothole. Took me about 45 minutes to figure out why my car "wouldn´t start".
[/TD][/TR][TR][TD]
[/TD][/TR][TR][TD]
[/TD][/TR][/TABLE]
the 1.9 LX´s have it too in case you didn´t know fer sure. at least my h/b does
[/TD][/TR][TR][TD]
[/TD][/TR][TR][TD]
[/TD][/TR][/TABLE]
I second that.
And just to be on topic, if your car senses it´s been in an accident, it will trip the fuel cutout, so you don´t drench your friends in gasoline, then ignite them in a rather gruesome, but enjoyable, ball of flames.
Yeah, for put those damn cutoffs on just about everything they make. That were always a SOB for the demo derby if you forgot to disable the switch. We used to run crown vics in the demo derby and 200 lap enduro. fun stuff, but dang electronics were more problems then they were worth.
1 - 18 of 18 Posts
