Engine - What type of funnel are you using to refill the radiator | Ford Escort Owners Association (FEOA)
Engine What type of funnel are you using to refill the radiator
Discussion in 'Tech & Repair' started by zzyzzx, Apr 22, 2019.
  1. zzyzzx
    14,984
    1,165
    I forget if 1st gens have that angled radiator cap...
    Are any of you using one of those special funnels to avoid spills when refilling the radiator?
    Like this one:
    Lisle 17232 Right Angle Funnel
    https://www.amazon.com/Lisle-17232-Right-Angle-Funnel/dp/B00MEPIU4M/
    [​IMG]
    Or one of the other special funnels specifically designed for this?
    The reviews suggest that people find other uses for these things.
  2. zzyzzx
    14,984
    1,165
  3. denisond3
    10,008
    2,756
    I use a small funnel that is fairly long; about 9 or 10 inches, and is tapered all along its length. Some coolant drips out when the rad is almost filled. Then I start the car, rev up the engine, and can put another pint or so into the rad.
    After that I make sure the recovery bottle has a few inches in the bottom, and I check the coolant level a few times in the mornings, to make sure its filling itself by 'drinking' from the recovery bottle. I check the level in the radiator, and the level in the recovery bottle.
    I use the same funnel when refilling the automatic transmissions.
    Pizzaman5000 likes this.
  4. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,337
    1,058
    Vancouver Island, Canada
    On my second generation wagon, I just very carefully pour the coolant jug directly into the radiator. With those long funnels you have to be careful not to fill the rad and have a bunch of coolant still in the funnel.
    If I spill a small amount I just wash it away with a bit of water.
  5. 88ESCORTV6
    1,235
    235
    313
    Hawkesbury Ontario
    this is what I use for everything no bleeding needed works with a vacuum. one of my best tools.
    austin86 and denisond3 like this.
  6. austin86
    685
    207
    58
    Ohio
    I never used one. I just filled up the res and then topped off the rad with what was left in the jug.
    No spills because I'm a real man.
