BAH, My Ground Control Coilovers aren't that stiff, I'm running the standard Eibach sprigs taht came with the set. I have never had anyone complain about the ride quality one guy even said it was nice compared to other lowered cars he'd ridden in. Springs are definitely going to be smoother, but they don't allow you to raise the car back up if needed, coilovers can do that.
Coilovers are good if you plan on doing more than just drag racing, they allow you to adjust each corner for track racing. (corner weighing I believe it is called) But a set of good coilovers (Ground Control or Dropzone are the two I think are best) are going to be expensive. $400+shipping is the going rate for GC coilovers and then another $200 for the ZX2 S/R struts to your door. but well worth it if you want a good starting suspension for racing. More addons later make it a real cornering machine.
Also with the spring rates, you can get softer springs for the coilovers too that will make the ride smoother, they just come standard witha mild race spring, but like I said, it isn't any worse than my car was on bad struts with old springs from the previous owner, its actually smoother now. And for the tires, if you run low-profile you will feel more road imperfections, hence why I am planning on running 15-16" rims with a good amount of rubber, helps keep a smoother ride and actually cuts weight over larger, flashier rims.
