1 - 7 of 7 Posts
Banhammer available, no waiting!
6.5 in the front and 5 x 7's in the rear deck for the GT. The sedan has 6.5 in the rear. Hope this helps. :wink:
Should be 5 1/4 but compare the depth of the stock speakers with the new ones you buy or your window will hit the magnet when it's rolled down. Oh yeah and if you try to just cut a hole through your door panel and bolt the speaker through it and into the door you'll find that once you put the speaker grill on , the window handle(manual windows) will hit it. If you got power windows then your OK or you can buy shorter window handles. Hope that helps
I got rockford fosgate 5 1/4 in the front and I was able to put in the door cover speaker over it. It was really tight but it worked...
Oh, and the best way to get those window handles off is with a little towel you put behind the handle. It will come off easily.
1 - 7 of 7 Posts
