What other larger TB can I get to fit. | Ford Escort Owners Association (FEOA)
Discussion in '2nd Gen 1991-1996 1.8L DOHC' started by uglyducklingescort, Oct 14, 2008.
  1. uglyducklingescort
    uglyducklingescort New Member
    997
    Tulsa, OK
    I have seen a what was to be believed a mustang TB on an escort. All I care about is being able to match it up and it having a variable resistor TPS. I already assume that I will need to drill out the holes or make new ones.
    Also I really don't care about the IAC either.
    Ideas?
    -Steve
  2. atomicEGT
    atomicEGT Guest
    198
    The throttle plate from a high-port SR20DE is a few mm bigger and will fit a stock EGT TB with minimal fabrication.
  3. uglyducklingescort
    997
    Tulsa, OK
    The shaft the same size or larger? How about the TPS?
  4. atomicEGT
    atomicEGT Guest
    198
    The only thing you use from the SR20 is the throttle butterfly itself. Everything else comes from the EGT.
  5. srad2drag
    srad2drag Guest
    104
  6. scp
    scp New Member
    94
    we have a guiy on TeamZX2 that does this ill post a link...
  7. yunvmyegt
    yunvmyegt New Member
    274
    boston, ny
    anybody try them, i got a few i could send one in to try out....
  8. srad2drag
    srad2drag Guest
    104
    Maxbore did the throttlebody on my Escort GT..Works great too
  9. Skuce
    Skuce FEOA Member
    3,307
    5
    288
    Ontario
    What was the diameter you got?
  10. srad2drag
    srad2drag Guest
    104
    They bored it out to 60mm at the butterfly
  11. darkstarmotorsports
    darkstarmotorsports Guest
    157
    how much it cost?
  12. Bomdoutscort
    Bomdoutscort FEOA Member
    1,249
    10
    288
    Cincinnati, Ohio
    well if you look at the website it says 135 for anything thats not a honda.
  13. uglyducklingescort
    997
    Tulsa, OK
    Honda's are overrated boat anchors also.
    I think I am going to put my Vtec is faster on the back of the car.
    -Steve
    What size is the stock TB and how big is too big?
  14. srad2drag
    srad2drag Guest
    104
    You cant go but so big with the stock tb because its only so much material.
  15. HANSTECH
    HANSTECH Guest
    when you get a bigger tb, will it mess with the idle alot? whats stock mm for the tb?
  16. Bomdoutscort
    1,249
    10
    288
    Cincinnati, Ohio
    it shouldn't because when they bore it out they put in bigger plates so the ratio of plate to throttlebody stays the same.
