Hello, I used the search but could not find the info I need. I'm swapping a 1994 EGT engine into a 1991 Capri. At this point, the the engine is mounted and runs. Due to clearance issues, I'm using a 4 wire Escort TPS on the Escort auto throttle body. The Capri also uses a 4 wire TPS. As far as I can tell, the sensors are electrically the same, but have different connectors. Can someone tell me what each of the four pins on the EGT TPS is for so I may cross reference the Capri shop manual?
To clarify, I have wiring diagrams to complete the job, but I need to know which of the four unmarked pins is which on the Escort's throttle position sensor. Attached are the relevant snippets of the wiring diagrams.
