1 - 7 of 7 Posts
your in luck! i just took some off
on the front right they are 17 mm
on the fron they are 17mm
but on the rear, you will see a 17 mm nut, yet these are welded to that mount bracket, you have to take the bolts out, they are 14 mm, you then will have to jack up your engine about 2" then you can take the top bolt out, or the subframe will be in the way, ford did not make these cars for shade tree mechanics to work on!
therieldeal said:
99% of the bolts on the car will be:
10
12
14
17mm
the exceptions are for oddball stuff, like 32mm axle nuts, 21mm for the lug nuts, etc.
the lug nuts are metric????
The Lug Nuts are 12MMX1.5 with a 21MM head.
Fortunately, 21MM is VERY close to 13/16", therefore a 13/16" socket can USUALLY be used for these lugnuts, if a 21MM isn't available.
1 - 7 of 7 Posts
