Doesn't seem to be an exhaust subsection so here goes. After seeing some pics of a 1st gen pacesetter header, which I thought I had, leads me to believe that I, in fact, do not have a pacesetter. When I was running open header, around 3500rpm I had to fight the wheel to stay straight from the torque the motor was putting out, the o2 bung is in the running of cylinder 3, any other info needed and I'll try to answer. 1-4 merge, and 2-3 merge, while it appears that the pacesetter has 1-3 and 2-4, firing order of the bp is 1-3-4-2
I didn't take any pics of it out of the box it was shipped in, so here goes:
This is a 91 GT with, originally, stock exhaust system.
Gap between end of header which appears to have a ball type ender with "loose" flange
Another view with the flange in the shot
Top view
Side view from front of the engine to the back of the engine
Hooking under the engine block and going to the back of the car
And the little extension pipe that I had a buddy fab up for me so I could listen to my music again
[/u]
Top view
