What did you do to your wagon today? | Page 24 | Ford Escort Owners Association (FEOA)
Discussion in 'Escort Wagons' started by NightWulf, Dec 29, 2010.
  1. novanutcase
    novanutcase FEOA Member
    2,471
    586
    263
    Had a '68 Bug and tinted the windows that dark. I had to roll the windows down at night to be able to see what was in the sideview mirrors. Sucked when it rained.
    I think I'm going to go with a more smoke type of tint. Not so dark. Just enough to cut the sunlight when it gets a little TOO sunny out this way. I'm sure tint that dark will be great when it's really bright out or when you have some lifted F150 with bar fogs riding your ass but for me it was kind of a hazard not being able to see clearly at night.
    John
  2. Intuit
    Intuit FEOA Member
    7,525
    916
    Southwest Ohio
    Although you want to be able to see where you're turning before you get there, (pedestrians and bicycles typically don't have lights,) there are those who do cut-outs in their tint for the side mirrors.
  3. novanutcase
    2,471
    586
    263
    I've seen that before but to me that is a big red flag to the local LEO. In my state they're pretty anal about no tint on the driver or passenger side windows. Most officers that I've talked to tell me they don't have a problem with smoked windows as long as they can see inside when the windows are rolled up. They don't like dark tinted windows because they can't tell what's on the other side of the window before it gets rolled down if they have to do a traffic stop.
    John
    copcarguy likes this.
  4. dmcmillan1214
    dmcmillan1214 FEOA Member
    52
    10
    8
    uploadfromtaptalk1432520422406.jpg uploadfromtaptalk1432520435083.jpg uploadfromtaptalk1432520455916.jpg uploadfromtaptalk1432520472549.jpg . Finally got to wire up my fogs! What a difference fogs made, and so much characteristic a gt bumper makes!
  5. novanutcase
    2,471
    586
    263
    That looks GREAT! I've been thinking about mounting one of those LED truck light bars in the center and leave the fog light holes on my bumper cover for turbo air inlets.
    John
  6. EscorGo
    EscorGo FEOA Donator
    3,006
    138
    213
    Wichita, KS
  7. dmcmillan1214
    52
    10
    8
    That's a nice looking scort! Good luck on selling it!
  8. EscorGo
    3,006
    138
    213
    Wichita, KS
    Thanks. It has been a fun car to play with.
  9. logan13848
    logan13848 FEOA Member
    19
    9
    I noticed that air compressor. Have you had any problems at all with it? I haven't seen a bad review yet and I want to know how it works for you.
  10. Jermo
    Jermo FEOA Member
    37
    7
    38
    St. louis, mo
    Today I replaced motor mount, put in tracer corner lights, and did a little more body work.
  11. denisond3
    10,011
    2,756
    Im working on a friend's 96 wagon. It had a bad head gasket, and the top of the block has enough dark areas on it (from water) that I will pull the block out and have my machinist maybe take a few thousandths off the top
    . I also spent quite a while with my electric impact wrench, loosening/resnugging the two bolts on the front of the front to rear crossmember under the bell housing, so I can drop that crossmember down. The reason to remove the crossmember is so I can use my pry bar to remove the driver's side CV axle from the transmission. The CV boot is ripped open, and it looks like its been that way for a long time; the grease that got flung out is well coated with dirt.
    I also need to free up the horizontal equalizers on the brake calipers; the pads are wearing unevenly.
  12. dmcmillan1214
    52
    10
    8
    Logan13848 So far its been good to me, only thing that's bad is that you need to make sure you have a 110 outlet dedicated to it, if I have the radio plugged in, the garage lights on and the comp kicks on it will trip the breaker on the comp itself. But it works good with the compacts, air ratchets, die grinders, Etc. I have the earth quake 1/2 and works good together.
  13. Intuit
    Intuit FEOA Member
    7,525
    916
    Southwest Ohio
  14. Intuit
    Intuit FEOA Member
    7,525
    916
    Southwest Ohio
    Most cams suck at nighttime pics. What did you use ?
  15. dmcmillan1214
    52
    10
    8
    Intuit as in what did i use? i used my galaxy s5 to take the pictures.
  16. Rectilinear
    Rectilinear FEOA Member
    154
    30
    128
    Plano, TX
    Just received new Motorcraft plug wires and a new thermostat housing yesterday for the Zetec. After that all the car will need is a valve adjustment since I never did that after the swap. May not get around to that before selling it. I need a bigger vehicle to haul my tools and materials around in for my new business. Looking at possibly getting another Volvo wagon (940 Turbo). This Escort is great fun to drive but I'm ready to get back to my roots.
  17. EscorGo
    3,006
    138
    213
    Wichita, KS
    You might look at a Focus wagon. It's larger inside than the Escort and I'm getting 29-30 MPG with the 130HP Zetec in my '03 auto. Can't get that in the Volvo.
  18. Rectilinear
    154
    30
    128
    Plano, TX
    I can get low 20's out of a Volvo redblock and have a larger and more robust vehicle. I was looking at getting a Transit Connect for my new business but I am going to start out slow and keep my cash outflow lower than that. The 940 turbo I am looking at belongs to a friend of mine and is in very good condition AND has a sales price of only $1K which is super cheap for this car. It needs the a/c fixed and should probably have the turbo rebuilt soon since it smokes under heavy load. So that is still under $1500 for a gorgeous 945T. Even better, I have lots of spare parts for Volvos and redblocks lying around the house. The Volvo will be extremely easy to work on in comparison to the Escort or a Focus. The Zetec swap I just did required me to take off an entire week from work to complete and that was with a parts car sitting right next to it. If it had been a Volvo, that job could have been done in a day or two. I have Volvo in my blood and it is hard for anyone to understand if they have never owned a proper RWD Volvo. There is something very special about then and something I have missed dearly since I bought the Escort. The Escort is stupid fun to drive now with the Zetec in it. It just does things an Escort shouldn't do. But I will be listing it for sale soon after I have the chance to replace a heater bypass hose and replace the a/c compressor. It just got a fantastic set of Contenintal tires on it last week on the ZX2 wheels.
  19. novanutcase
    2,471
    586
    263
    Wow! After all that work too. Sorry to hear that you're getting rid of her but I'm glad you were able to find a Volvo that works for you.
    Good luck on your new business and pop in every once in a while and say hello!!!
    John
  20. Rectilinear
    154
    30
    128
    Plano, TX
    Will do, I'll still be hanging around a bit and will certainly be glad to give any advice on the zetec swap that I can.
    BTW, I fixed the leaky heater hose and replaced the thermostat housing. But the big win came from the new set of Motorcraft plug wires. I can't believe how smooth the idle is now and I lost all of the off-idle stumble and top end cut out that I was experiencing before.
    I think Graham knows that I am wanting to get rid of him, he is starting to shape up!
    All I still need to do is replace the a/c compressor and drier, plastidip the passenger side window frames and do a good cleaning and it will be ready to go!
