What did you do to your 3rd gen today?? | Page 183 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by ndlm8888, Aug 2, 2013.
  1. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    I'm gonna have to watch that. I didn't bolt mine tight yet.
  2. copcarguy
    copcarguy FEOA Member
    1,980
    847
    263
    Northeast PA
    dchawk81 likes this.
  3. dchawk81
    3,450
    940
    173
    I'm thinking I should replace my switch since I've already got the hose off. Now would be the time...as opposed to charging the system only to have it fail.
  4. sturgilln
    sturgilln FEOA Member
    70
    20
    38
    Got the new headlights on today; here's a before and after:[​IMG]
    [​IMG]
    [​IMG]
    ar154all and dchawk81 like this.
  5. dchawk81
    3,450
    940
    173
    Hella difference!
    sturgilln likes this.
  6. sturgilln
    70
    20
    38
    ALSO, got my cluster with tach! No time to install it for about 3 weeks but I will put up pics when I do? (40 dollars eBay)[​IMG]
  7. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,155
    654
    263
    They are self adjustable. They have to be properly adjusted manually, like that pdf says. After that pumping the ebrake lever should adjust them. The lever also has an adjustment. If swapping from drum to disc, the lever will need to be adjusted too.
  8. ar154all
    ar154all The Police never think its as funny as I did.
    1,002
    213
    93
    Florida
    Sexy.
    seriously.
    I LOVE a great set of headlights.
  9. EscorGo
    EscorGo FEOA Donator
    3,006
    138
    213
    Wichita, KS
    Ditto! I just put new ones on the Focus wagon and did a full facelift on the Suburban. All new lamps, bumper and color matched grill.
    [​IMG]
  10. dchawk81
    3,450
    940
    173
    Sweet. Headlights for my Nav are $100 each, generic. So I'm like yeah that's gonna wait.
  11. copcarguy
    1,980
    847
    263
    Northeast PA
    There's a way to adjust the lever? Mine are factory discs. It seems like every 6 months or so, I gotta fiddle with them as they don't feel "right".
  12. ar154all
    1,002
    213
    93
    Florida
    Dude. I have a 94 green burb. What year is yours?
  13. EscorGo
    3,006
    138
    213
    Wichita, KS
    '93. I'm getting a new headliner installed this week. Too long for me to handle.
  14. dchawk81
    3,450
    940
    173
    That's what she said.
    EscorGo likes this.
  15. EscorGo
    3,006
    138
    213
    Wichita, KS
    LOL I wish !
  16. ShakeZilla19
    3,155
    654
    263
    Yes, you take the center console out. (Like 2 screws). Then you can see the lever mechanism, it has a small nut on one side (8mm I think). You just tighten it to make the e brake engagement lower.
    I swapped disc brakes on for a few months and never had a problem. Even used the drum's prop valves.
    copcarguy likes this.
  17. ar154all
    1,002
    213
    93
    Florida
    its not a 2 piece liner?
    I am looking to do a 6.0 vortec conversion in mine, the 'ol 350 has finally took a dump.
  18. EscorGo
    3,006
    138
    213
    Wichita, KS
    I think it is. I have the dual air. Not as easy as the 'scort headliner was.
    Always better to go newer if you have the smarts. I was going to replace the tired 4L60E with a 4L80E but I'm hung up on the crossmember. It has to be modified. No one sells conversion for these years
  19. copcarguy
    1,980
    847
    263
    Northeast PA
    THANKS SHAKE! Today I re-adjusted the rear calipers again, then I popped the armrest & center console off. I took a good inch out of that adjustment screw at the handle. I went from virtually no e-brake to mega-grip lol. The handle only moves up a couple of inches now, where before it would literally hit the armrest. Much appreciated for the heads up!
    I also adjusted the air-gap on my A/C compressor. A Thank You to rbailin for that helpful tip! IMG_2051.jpg
  20. Vbv58
    Vbv58 FEOA Member
    238
    66
    128
    Quick question, What's up with my girlfriend's 'scort and keyless entry? The fob says driver door only, and sure enough the fob only unlocks and locks the driver door...would switching to a different fob like mine (unlocks all 4 doors) make all the doors lock and unlock, or is it just a piece of crap factory option to unlock the driver door only? I've never heard of a keyless entry only unlocking 1 door. Usually it unlocks the driver door on 1 click, and all doors on 2 clicks. Or possibly could the other 3 doors have some other problem?
