What did you do to your 3rd gen today?? | Page 182 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by ndlm8888, Aug 2, 2013.
  1. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    Yeah mine was a V6. I forgot it's still a 4 banger in the Escort.
  2. Vbv58
    Vbv58 FEOA Member
    238
    66
    128
    Yeah. For a 4 cyl though, I think the SPI CVH has a pretty good sound...especially if you mod the intake. I plan on doing a 3.8L TB swap soon and I hope it makes it sound even better. What do you guys think? Good sound or "just another 4 banger?"
  3. ShakeZilla19
    ShakeZilla19 My name is ^^^
    3,161
    659
    263
    The 3.8l Tb is a bit over kill... Apparently WRC, 4 bangers, have the same size, 44mm, TB as the 2.0 SPI yet make upwards of 600HP. The stock TB isnt a restriction, adding a huge TB is only going to drop flow velocity.
  4. ar154all
    ar154all The Police never think its as funny as I did.
    1,002
    213
    93
    Florida
    CCRM (AC), timing belt, motor mounts, dents, paint, bad headlight wiring on the passenger side. Maybe a trans rebuild...
    It will make a hell of a parts car if I get another G3, Its nall going to boil down to money...
  5. dchawk81
    3,450
    940
    173
    I honestly never really gave the sound much thought beyond wondering if I had an exhaust leak.
    Ah. Sounds like my POS. ;)
  6. dchawk81
    3,450
    940
    173
    BTW who all here has a '97 and can help me remember where the two hoses coming off the evap canister (under the CCRM) go? They run side by side for the most part and go somewhere in the direction of the firewall.
  7. copcarguy
    copcarguy FEOA Member
    1,983
    848
    263
    Northeast PA
    I'm not near the wagon right now, but drop me a line tomorrow before lunch and I'll look and/or take pics, etc...
    dchawk81 likes this.
  8. dchawk81
    3,450
    940
    173
    Awesome thanks! I'm not ready to drop the motor in yet, but I did get the ear welded. Gotta get this posh wedding behind me first.
  9. madmatt2024
    madmatt2024 FEOA Member
    9,835
    400
    383
    Upstate N.Y.
    As I recall from my 97 one goes to the bottom of the throttle body and the other goes to the EVAP line coming from the gas tank. There is also a sensor and solenoid valve I think on the line going to the throttle body.
  10. ndlm8888
    ndlm8888 scortin daily
    983
    341
    213
    tampa bay ,fl
    [​IMG]
  11. dchawk81
    3,450
    940
    173
    I lied. Motor is back in.
    [​IMG]
    That sounds right. And I have the solenoid line laying here.
    I'm too dumb for schematics to help. :-/
    ShakeZilla19 likes this.
  12. madmatt2024
    9,835
    400
    383
    Upstate N.Y.
    Then put down your tools, you are too dumb to work on a car. :p
    Its a really simple schematic, the part shapes are even well represented.
    EFCA= nipple on bottom of throttle body.
    Thermistor = Purge flow sensor
    EVAP purge valve = EVAP purge valve
    Canister = Canister
    V REST = I don't know, never saw it on my car. Its probably a hose coupler that some sort of flow restrictor in it.
  13. dchawk81
    3,450
    940
    173
    I've never been able to work off schematics for some reason. My brain just never seems to translate the drawing to the real thing.
    I tried working for Ingersoll-Rand (now Volvo) building those double drum rollers used for paving and it was a no go. What the book showed me didn't help me see what the machine required.
    I was responsible for running the hydraulic lines and I just didn't "get" it.
    [​IMG]
  14. madmatt2024
    9,835
    400
    383
    Upstate N.Y.
    All it is is :component: :hose: :component: Don't question it, just do it. Make it look as neat or as sloppy as you want.
  15. ShakeZilla19
    3,161
    659
    263
  16. cklaubur
    cklaubur Former Escort Owner
    1,748
    41
    298
    Now in Mesa, AZ
    I replaced mine.
    I was replacing motor mounts, and broke one of the rear crossmember studs on the front subframe. I was actually looking at replacing it in a couple of months anyways with something newer and with fewer miles. I ended up in an '07 Focus hatchback.
    Casey
  17. copcarguy
    1,983
    848
    263
    Northeast PA
    I tried to do my mounts a while back. The drivers side stud snapped and I gave up. I soaked everything with WD AND PB Blaster and nothing else would budge.
  18. dchawk81
    3,450
    940
    173
    Mine were well lubricated with transmission fluid from the leak. Hah
    Not that it mattered for the rear tranny mount since I had to replace it.
  19. Vbv58
    Vbv58 FEOA Member
    238
    66
    128
    Flushed brake fluid, replaced pads (ceramic) and rotors. The old pads were almost down to the worn indicator so it's good I got them done. Also lubed the caliper pins and cleaned the shit out of the whole area. My car can stop safely now. I can slam on the brakes at 60 at stop in 4 seconds flat. With my old brakes you could slam on the brakes and you would wonder if you were ever going to actually stop. Next up is replacing the bushings on my shifter, and installing my short throw :)
  20. cklaubur
    1,748
    41
    298
    Now in Mesa, AZ
    On mine, everything came apart fine. It was after I put everything back together and was torquing everything down when I broke the stud.
    Casey
    copcarguy likes this.
