What did you do to your 3rd gen today?? | Page 172 | Ford Escort Owners Association (FEOA)
Discussion in '3rd Gen 1997-2002 2.0L SOHC' started by ndlm8888, Aug 2, 2013.
  1. Gamer92
    Gamer92 FEOA Donator
    3,433
    978
    263
    Southern Indiana
    Yea I re-read your post and saw you didn't want the sticky ones my bad.
    I actually bought these a few months ago and returned them since I did not want the sticky stuff on my car. Do the ones you're looking for just slide on or something?
  2. copcarguy
    copcarguy FEOA Member
    1,979
    845
    263
    Northeast PA
    They fit in the weatherstripping channel where the glass rides up & down. This way, they can't be stolen or ripped off. Plus, I think they look more integrated & streamlined.
  3. copcarguy
    1,979
    845
    263
    Northeast PA
    image.jpg image.jpg Today I changed the oil, rotated the tires, washed the inside of the rims while they were off, and changed CCRM's. At first the compressor did nothing and I got a pit in my stomach. I turned the a/c off and back on and the compressor would not turn off unless i turned off the knob in the car. It wasn't cycling on & off. I googled what might make the compressor not shut off, the first answer was it might not if it's idling and a very hot day. So I went for a ride around the block and it was ice ice cold and cycling on & off. I hope it's fixed.
    PS: you'll need a 5mm socket to get the bolt out of the wiring harness, and a 5.5mm socket for the two tiny screws holding the CCRM onto the mounting bracket. I had to look through a few tool sets I had to find a 5.5mm socket.
    rbailin, dchawk81 and Tnashua like this.
  4. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    Is that a NOS CCRM?
    What made you pinpoint that as your problem?
  5. madmatt2024
    madmatt2024 FEOA Member
    9,830
    397
    383
    Upstate N.Y.
  6. copcarguy
    1,979
    845
    263
    Northeast PA
    Yep, it's new old stock. I got it on eBay a year or two ago. I figured one day I'd need it lol.
  7. dchawk81
    3,450
    940
    173
    Good call. I'm trying to work out why my Navigator AC suddenly failed and has blown hot ever since.
    Tried a simple recharge and that wasted $40. Hate to throw parts at it though.
    Could be my compressor because I don't remember hearing it kick on but since the CCRM controls it...tried tapping that and it didn't do anything.
    It has 199k on it now but it runs so well and I've got so many new parts I might suck it up and replace the compressor and all the lines at one time. At least I'd have the compressor and leaks ruled out.
  8. MenaceMan47
    MenaceMan47 FEOA Member
    248
    62
    178
    New Mexico
    Replaced the fuel filter and spark plugs. Found a dry-rotted-to-hell vacuum hose connecting between the bottom of the throttle body to a plastic line that runs along the firewall to the passenger side of the engine compartment. I believe I found my idle issue... it idles even better now and my fuel economy improved immediately. Even better, Autozone gave me the 6" length of vacuum hose to fix it for free. I'm honestly surprised I didn't see the hose sooner, with all of the fuel filters I've replaced over the years. It was a good day today.
  9. rbailin
    rbailin FEOA Member
    1,234
    368
    333
    I see from the 2nd photo that you're missing the cap for the high side A/C connector. You might want to pick one up from the junkyard. It's not just a cosmetic thing, it keeps out dirt that could clog the valve or get into the system, and it also seals against minor valve leaks.
    copcarguy likes this.
  10. rbailin
    rbailin FEOA Member
    1,234
    368
    333
    Just run a wire from the + battery post to the single connector on the compressor. If the clutch kicks in and the compressor runs, then it's not the compressor. Then the only things left are the low pressure cutoff switch on the receiver/drier, the high pressure cutoff switch next to the high side connector, and the CCRM A/C relay, with the CCRM being most likely to fail.
    Let us know if the clutch doesn't kick in when applying direct battery voltage.
  11. dchawk81
    3,450
    940
    173
    Good idea. I'll give it a shot.
  12. copcarguy
    1,979
    845
    263
    Northeast PA
    I thought that was just something for looks, I didn't know it did all that stuff too! I wonder if a parts store would have it as junkyards are not near here.
  13. copcarguy
    1,979
    845
    263
    Northeast PA
    Just looked at rockauto, they have a cap kit for $3.24. I'll include it in my next order. Thanks!
  14. rbailin
    rbailin FEOA Member
    1,234
    368
    333
    RockAuto cap & valve kit https://www.rockauto.com/catalog/moreinfo.php?pk=5916006&cc=1380507 $3.24
    Obviously, you only want to use the caps. Keep the valve stems for future repairs.
  15. copcarguy
    1,979
    845
    263
    Northeast PA
    Looks like we had the same thought about rockauto lol. Do you know if when replacing the two switches (low & high cutoffs) if you must open the a/c lines or do they just unscrew without losing refrigerant?
  16. rbailin
    rbailin FEOA Member
    1,234
    368
    333
    Both switches screw onto Schrader valve stems (like on tires or the fuel pressure port) that close and seal as you unscrew the switch. Two things you can change on the A/C system without a discharge/recharge (the other being r&r the compressor clutch). But the switches seldom go bad and you can easily test them by removing the connector and shorting the two terminals together.
  17. DrewsBrews
    DrewsBrews FEOA Donator
    326
    137
    103
    SW Ohio
  18. Vbv58
    Vbv58 FEOA Member
    238
    66
    128
    Not a sedan or wagon, but today my buddy and I replaced the fuel pump in his ZX2...Pretty straightforward and it's drive-able again..It's slower than my 'scort though...but for a engine with 202k miles (and no mods), it rides pretty smooth :)
  19. dchawk81
    3,450
    940
    173
    SUV compressor kicks on (I can hear it when I play with the HVAC switch) and it seems to still be holding freon. Got a second can to see if it would take more than the initial 20 ounces. It took another 12 ounces but still showed pressure from the first fillup. I think it's okay as far as that goes.
    I don't know how to test the cutoff switches.
  20. 22732
    22732 Guest
    Reminds me of my parents '83 toyota tercel 4wd sr5 wagon they used to have when I was a kid. That plaid interior was awesome. Good job! How's everyone doing on here? Definitely more sense of a helpful community here and I miss that. The chrysler 300 forum just isn't the same where the car is still in production and typically full of people who seem to have tons of money etc
    copcarguy and dchawk81 like this.
