1. Clean up your engine. (5$) Find if any guskets are leaking. Replace them (~50$) if needed.
2. Replace Spark plugs with NGK Iridium (40$). Replace Spark plug cables (90$), replace Coil Pack to MSD coil pack. (90$)(Accel Is GARBAGE)!!
3. Remove any unnessosary plastics and covers.
4. 3" Intake tube (Will need that big for future upgrades) (I paid 84$ CAN for custom made one), Bracket and K&N Cone Filter (80$) Cold air extension (20$) Can go RAM air (you´ll need to cut a fender base to do that) ($20)
5. 3.8 Tauros or Tbird TB swap. (25$ form junker) Will need to make few custom things. Like braket for a cable and etc. In the same time port match and polish you intake manifold. Inlarge mixture chambers.
6 Headers, free flow cat, 2.25" Piping from cat, elemenating resonator and Perfomance Muffler. I´m in love with Magnaflow. Other people like others.
7. Higher lift camshaft, hi-rev lifters, doube springs, Port and polish engine head. Aluminium pulley, Ballancing.
8. Crankshaft bearings, Piston rodes, Pistons.
9. Turbo eather from EXP or British RS Escort. Large injectors, blow off and etc.
10. Custom computer reprogramming.
All that will give you about 300hp.
Ohh yeah I forgot clutch and lightened flywheel.
[ Edited by AleX On Date 08-08-2002 ]
