Weight in Glovebox | Ford Escort Owners Association (FEOA)
Weight in Glovebox
Discussion in 'Interior Modifications' started by novanutcase, Aug 24, 2016.
  1. novanutcase
    novanutcase FEOA Member
    2,514
    592
    263
    I remember someone talking about a weight that Ford put in the glovebox to make it easier for it to open. How does one remove it?
    John
  2. denisond3
    10,040
    2,773
    When having a glove box out, I dont recall seeing a weight - not that I have really looked for it. My wife and daughters keep the 'glove box' filled with so much miscellany that I have to keep the owners manual (and any gloves) under a front seat.
  3. pextor
    pextor Moderator Staff Member
    5,928
    790
    Lancaster, pa
    there are two stops that bend in to release the glove box so you can remove the whole assembly.
    there are screws that hold the glove box onto the dash.
    there are screws that hold the two halves of the glove box together.
  4. novanutcase
    2,514
    592
    263
    Thanks. I guess my question is is there a weight to help the glovebox open? I read that it weighs around 5 pounds which seems kind of unlikely but I was just wondering.
    John
  5. dchawk81
    dchawk81 FEOA Member
    3,450
    940
    173
    Never noticed one in mine. I guess they figure you'll have enough crap in there that it won't have trouble opening.
  6. pextor
    5,928
    790
    Lancaster, pa
    I'm not sure what the thought is for why it's in there - if it's to help it open quicker/easier, if it's to keep it from rattling, or some other reason.
    People have taken them out with no ill effects that I'm aware of.
  7. luislop
    luislop FEOA Member
    52
    11
    18
    2001 ford escort zx2
    Wells guys i have finally done it took about 15 min with power tools.
    The weight is inside the glovebox plastic casing.
    1. Remove the glovebox from the vehicle, pull the tabs in and then remove the screws that hold the unit in place
    2. Dissasemble the glovebox you have 3 screws in each side and 2 in the middle the hold the locking mechanism.
    3. Once you have that off, u will be able to see the metal casing inside. It is fused to the outer plastic part of the glovebox by around 10plastic rivets.
    I used a angle grinder and went to town on those "rivets" just took the tips off and applied some leverage force and the metal plate/weight came off.
    4. Just assemble the glovebox back toguether, put it back and enjoy......
    5. The 1.5 pound weight savings(weighed in scale).....LMFAO. i was hoping it was heavier but what the heck, it only took 15 minutes.
    So there u go for anybody who is thinking on doing such thing to their escorts.
  8. novanutcase
    2,514
    592
    263
    Escort hacks! :)
    John
  9. neuspeedescort
    8,125
    98
    348
    wenatchee, wa
    it's not there for the purpose of opening easier. gravity will do it just fine with out. it's there as a safety feature. just like under the drivers dash area. it's to help protect your knees from getting in the dash in an accident or so i have been told.
