Weber 32/36 on a first gen? | Page 2 | Ford Escort Owners Association (FEOA)
Discussion in '1st Gen 1981-1990 CVH' started by austin86, Oct 14, 2019.
  1. Joey_Twowagons
    Joey_Twowagons FEOA Member
    2,379
    1,094
    Vancouver Island, Canada
    Weber carbs available from Carbs Unlimited near Seattle:
    https://www.carburetion.com/Weber/weberpartscarb.asp
    As you can read on their site, there seem to be fake Weber carbs out there to beware of.
    I picked up my Weber used, cheap, locally, by keeping an eye out for "carburetor" in the online ads.
    But it's not on an Escort, rather a B2000.
    1982 EXPert likes this.
  2. austin86
    757
    243
    58
    Ohio
    Back at it with a carb. would a weber 38/38 be able to handle 200-250hp?
  3. 1982 EXPert
    1982 EXPert FEOA Member
    114
    92
    38
    I don't believe there is a Weber 38/38 for our carb manifolds, or are you talking about the downdraft/sidedraft duals?
    A lone 38/38 would in theory be better than stock 32/32 (or 32/34) power-wise but that's still not as awesome as duals or bike carbs. But a pair of 38/38s would be impressive if you have a race engine, my math says the biggest you could go is 37-39mm per cylinder unless you're making serious boost.
    The duals (and bike carbs) have been known to reach the 150-180hp range well, but getting past that N/A is hard, you can turbocharge/supercharge carbs though. Turbocharging a 2-barrel carb gets 150-180hp with low boost and few mods besides a LOT of jetting haha. Turbocharging the duals or bike carbs would get you to/past the 200hp mark with ease, but the methods for it are beyond my expertise....
  4. austin86
    757
    243
    58
    Ohio
  5. 1982 EXPert
    114
    92
    38
    I like that link, describes exactly what I'd say the difference would be.
    This guy really liked the 38/38 over the 32/36:
    If the 38/38 has an accelerator pump maybe you can make the 38/38 progressive, that would better suit my desires naturally aspirated at a semi-stock level.
    austin86 likes this.
  6. 1982 EXPert
    114
    92
    38
    Recently found another carb option for those enquiring about it.
    Weber 34DATR or 34DMTR
    It's pretty much identical to the stock carbs but a 34/34 progressive instead of a 32/32 or 32/34 progressive. Still doing research on them but they're kind of hard to find.....
    Later found a Weber 40DCNF
    It's synchronous like the 38/38 but this one is an older design found on Ferraris and seems to share the bolt pattern of our stock manifolds.
    But I know there's Weber manifolds to allow 2 of them on a CVH hemi head.
